Unable to Order a catalog item in portal using ATF
Supritha3
When i try to order a catalog item using "Order a catalog item(sp)" it is failing with the summary as "FAILURE: Validations failed. Failed to Order Item." These are the steps that i followed, and also once I open the catalog item in the portal page, I am unable to find some fields even though i have defined those variables
Can someone please help me find a solution to this.
Supritha F
20 REPLIES 20
Hi @Ankur Bawiskar
I see the same message "FAILURE: Validations failed. Failed to Order Item.", but in test logs, i do not see any additional error message.
I have a catalog item with one button on the page.
3 steps in ATF test Impersonate Open a Catalog Item (SP) Order a Catalog Item (SP) 1st 2 steps success. 3rd step failed with above error message.
Please let me know if you have any ideas/questions.
thanks
p
