Want to add One field in Pop Up of problem task record
Mk_snow
When we click on complete button on the problem task record, there is a popup that appears and i want to add one more field into that popup. not sure where and how to find its configuration.
Below is the Popup which is OOB functionality. I need to add one more field into it. please help me where to find this and add
Thanks in advance😀
Ankur Bawiskar
@Mk_snow
Simply check form view on problem_task which is used to render the fields in popup
-> just add/remove the fields in that correct view and it will reflect in popup
-> see below and compare the correct view
15 REPLIES 15
correct, this i saw which is responsible for popup but was not able to find the actual place where i can add the field in the popup
There is function in that you need to check that mate.
Ankur Bawiskar
@Mk_snow
view name is "ptask_complete_dialog_view_1" and the field is already resent on the view but still not visible in the popup
Attached screenshot and highlighted
Hi @Mk_snow
The form view is right, if you add new fields to this form layout, it should show up in the popup modal. Hope the new field doesn't have UI policies/client scripts to display it conditionally.
which field you were trying to add to the popup modal?
