12-26-2025 07:09 AM
When we click on complete button on the problem task record, there is a popup that appears and i want to add one more field into that popup. not sure where and how to find its configuration.
Below is the Popup which is OOB functionality. I need to add one more field into it. please help me where to find this and add
Thanks in advance😀
12-26-2025 07:44 AM
Simply check form view on problem_task which is used to render the fields in popup
-> just add/remove the fields in that correct view and it will reflect in popup
-> see below and compare the correct view
12-28-2025 10:29 PM
Hi @Mk_snow ,
Any update ?
If my answer helps you so please mark it correct and helpful.
Thanks and Regards,
Sarthak
