When do we use next(), hasNext() and _next()
chanikya
I have 10 records only on whole table , now I want to update records So
just to check if there is any record satisfying the query
hasNext() - does not actually go to that record but just tells true/false is there is any record matching the query
25 REPLIES 25
nope
you need to use next() method so that it goes to that record and then update it
If my response helped you please mark it correct to close the question so that it benefits future readers as well.
@chanikya
Let me know if I have answered your question.
If so, please mark my response as correct & helpful so that this thread can be closed and others can be benefited by this.
var gr=new GlideRecord('incident');
gr.addQuery('category','software');
if(gr.hasNext())
if(gr.next())
gr.description="ABC";
gr.update();
is it correct ? to check Query condition ?
Your code will run only once. To update all the records use below code
	while(gr.next())
		gr.update();
Hey upendra ,
i trying to find logic, when do we use hasNext() in Script,i want to know that.
