10-07-2026 10:09 PM
Details:
I have not added any client scripts, UI policies, or server scripts that clear or reset the values. Despite this, the variables are still being cleared automatically after saving.
Request:
Can you help me understand why this is happening and how to fix it?
10-13-2026 09:49 PM
Thank you to everyone for your responses.
Someone on my project created a section and added a variable editor to the task form. As a result, we were unable to save the variable values. After deleting that section, everything is now working fine.
10-08-2026 05:50 AM
Please provide more information. There could be a number of things wrong. Your description is to limited and a response like 'it was working before' doesn't help in pinpointing to the issue.
What form? Custom or OOB? Which table? What do the logs say? What did you already check? What happened between when it was working and now?
10-08-2026 06:04 AM
Hi @Mark Manders ,
1. We have a UI policies that makes variables read-only on both the sc_task and RITM forms.
2. I have a few mandatory variables on the sc_task form. When I set values and save the form, the values are not saved — they revert back to their previous state.
3. To troubleshoot, I deactivated those two UI policies.
The script on the UI policy is: g_form.setVariablesReadOnly(true);
10-08-2026 06:32 AM - edited 10-08-2026 06:32 AM
In one of my project, for a catalog, we faced the same issue once business reported it. That time root cause was "Clear the variable value" was selected in Catalog policy UI action. Once we unchecked it, it worked fine.
sample screen shot:
Check if you have same root cause - KB1064636 Variable editor field value cleared on catalog task record
Resolution
To stop the variable editor from clearing the field value, uncheck the **Clear the variable value** field on the Catalog UI Policy Action.
1. Navigate to the Catalog UI Policy Action for the catalog item that the task was created from.
2. Open the relevant Catalog UI Policy Action record.
3. Uncheck the **Clear the variable value** field.
4. Save the record.
After saving, the value will no longer be cleared from the variable editor and will display correctly.
10-08-2026 07:03 AM
Thank you for your response. We don't have any UI policy actions related to 'clear value' or 'value action.' It might be a system issue, but I'm not certain.
10-13-2026 09:49 PM
