‎01-12-2024 06:39 AM
For change Record, Trigger a approval notification when Inside Blackout Window record inserted in normal change record
For example
we have two approval notifications "A" and "B".
"A" approval notification should trigger when Inside Blackout Window record inserted in Normal change record and "B" notification should trigger when Inside Blackout Window record not inserted in Normal change record.
Change Management
‎01-16-2024 05:14 AM
Hi @Dr Atul - LNG
Thank you for quick reply
FYI = "A" Group approval is first level and "B" is second level Approval
Note=
while we approve "A" Group first level approval to "B" group is second level Approval....No fields are changing in change record...
Could you help me with screenshot to trigger a event in workflow
‎01-16-2024 05:19 AM
Hi @Dileep Raju
By mistake you accepted your answer as solution, could you please accept mine too , you can select more than 1 answer as solution.
In flow designer you can use the ask for approval or best is Change Approval Policy. where you design the same.
Please check OOTB polices.
‎01-21-2024 10:05 PM
Hi @Dr Atul - LNG
For my requirement
Could you please help me with example and screen shot how to achieve this requirement
1. A" approval notification should trigger to Group "A" when Inside Blackout Window record inserted in Normal change record
2. "B" notification should trigger Group "B" Approval. when Inside Blackout Window record not inserted in Normal change record.
Ans = I used Workflow Activity To trigger email
1. Notification on approval table in advanced condition for "A" Group 1st level Approval given below code
answer = false;
var str = current.wf_activity.name + ' ';
if (str == ' Group "A" ') {
answer = true;
and for
2. Notification on approval table in advanced condition for "B" Group 1st level Approval given below code
answer = true;
answer = false;
‎01-15-2024 04:38 AM
Hi @Dr Atul - LNG
Note=
Hi @Dileep Raju
Hi @Dr Atul - LNG
For my requirement
answer = false;
answer = true;
and for
answer = true;
answer = false;
