Where is Root Cause recorded in SN? Is there an ability to easily categorize / classify root causes for reporting purposes?
jimpignatiello
Kilo Explorer
As per my knowledge RCAs are associated with problem tickets and not incidents. So its better to raise a problem ticket from your incident tickets needing RCA.
The Kepner-Tregoe plugin is the only plugin provided by ServiceNow.
If you need a different process then you might need your own customization on the problem table for this.
Please look in to the requirement.   Please help me out with the possible solution.
rob_blakey
Hi Jim,
The way we did this on our form, under the Root Cause field, we added in two choice fields:
Root Cause Code (u_root_cause_code)
Root Cause Sub-Code (u_root_cause_sub_code)
Once we did that we created choice lists under each of them and made sub code dependant on Code
For example:
Root Cause Code:
Application
Hardware
Software
Environmental
Third Party
Sub Codes: (Keep in mind these are dependant so if you keep them universal you can easily copy them for each)
Training
Specification / Design
Inadequate UAT or Test Environment
Inadequate Documentation
Human Error
Data
Customer or Third Party System Failure
These are just some examples, but at least you get the idea see picture below for real life:PrtScr capture_2.jpg
