Why Gliderecord's getRowCount is not giving accurate result?
sarahmustakim
I'm trying to get the count of the number of features associated with a release. I have written an after business rule on Insert, on the rm_feature table with the below code:
  // Add your code here
  var gr = new GlideRecord("rm_release");
gr.addQuery("sys_id", current.parent);
  gs.log("Features = "+ gr.getRowCount());
while(gr.next()) {
    gs.log("INSIDE WHILE Features = "+ gr.getRowCount());
})(current, previous);
Both the logs are giving gr.getRowCount() result as 1...even if there are multiple features already associated with the release.
Please assist.
Sarah
Hi Sarah,
You are right.Your business rule should be in "rm_feature" table. Just change the script as below.
Change the script to:
  var gr = new GlideRecord("rm_feature");
gr.addQuery("parent", current.parent);
while(gr.next()) {
Mihir
Mihir Mohanta
1.Write business rule in the "rm_release" table.
2. Script:
var gr = new GlideRecord("rm_feature ");
gr.addQuery("parent", current.sys_id);
while(gr.next()) {
Check log.You can find the count of the number of features associated with a release.
Mihir
Hi Mihir,
I had thought of doing this, but couldn't decide on what condition should the BR fire.
Hi Sarah,
while(gr.next()) {
Mihir
Thanks Mihir,
This approach is giving the correct result!
I'm still confused though, as to why the glideRecord into the release form was not able to give the result.
Thanks, at least you found a workaround
Sarah
