‎11-04-2024 02:52 AM
Hi All...
Recently I configured KB form, where I put 'Activities' field & 'Work notes' field under a custom tab called 'Notes'. My issue is when I create a new article, 'Notes' tab capturing & showing all activities of the article (like workflow status, changing category, adding images, changing author etc). But when I open an existing article for a published article, the 'Notes' tab is showing activities only related to image updates.
Kindly provide your feedback/suggestions if u r aware of above issue.
Thanks in advance.
‎11-04-2024 03:39 AM
The answer will be on the dictionary entry for the kb_knowledge table. See below example
Can you attach a screenshot of the issue you're seeing
‎11-04-2024 03:43 AM
Hi @Hiranmayee Moha ,
You can control the activities visibility from here.
‎11-04-2024 05:13 AM
If your are checking in lower instance then due to clone work notes data usually do not migrate due to that it wont show for your historical data but if you are checking in prod then and work notes checkbox marked still not showing then something broken. On that case you can raise HI support ticket.
‎11-04-2024 04:38 AM
‎11-04-2024 04:45 AM
@Runjay Patel ...Hi,
Thanks for ur reply.
Work notes field is already checked. Issue is the existing articles not showing historical data related to work notes, whereas when I am creating a new article, it shows.
‎11-04-2024 04:53 AM
‎11-04-2024 05:16 AM
Notes Tab having: Activities (filtered) formatter & Work notes field. Issue is only with existing articles not new articles.
(Existing article)...Showing only related to images.
Existing article: showing all activities in another environment (same article no)
