Work notes updates not captured/showing in custom "Notes" tab of a KB article
Hiranmayee Moha
Hi All...
Recently I configured KB form, where I put 'Activities' field & 'Work notes' field under a custom tab called 'Notes'. My issue is when I create a new article, 'Notes' tab capturing & showing all activities of the article (like workflow status, changing category, adding images, changing author etc). But when I open an existing article for a published article, the 'Notes' tab is showing activities only related to image updates.
Kindly provide your feedback/suggestions if u r aware of above issue.
Thanks in advance.
3 ACCEPTED SOLUTIONS
The answer will be on the dictionary entry for the kb_knowledge table. See below example
Can you attach a screenshot of the issue you're seeing
Runjay Patel
Hi @Hiranmayee Moha ,
You can control the activities visibility from here.
If your are checking in lower instance then due to clone work notes data usually do not migrate due to that it wont show for your historical data but if you are checking in prod then and work notes checkbox marked still not showing then something broken. On that case you can raise HI support ticket.
Hiranmayee Moha
@Runjay Patel
Yes... I am checking in lower instances. It's showing in Prod.
Thank you so much !
