How to get same output of the script by using OOTB filter conditions of incident Records for cross checking purpose..??
satish samrat
inc.addActiveQuery();
inc.orderBy('number');
inc.chooseWindow(2,10);
inc.query();
while(inc.next()){
  gs.print(inc.number);
Chandu Telu
Hi Satish,
Looks Like we don't have OOTB option to choose build for choose window and we have like
active=true^numberBETWEENINC0000002@INC0000017
Chandu Telu
Please Mark Correct/helpful, if applicable,
Community Alums
Hi @satish samrat ,
Use the below condition :
Sandeep
Community Alums
Hi @satish samrat ,
Any update to this ?Any follow-up required? if not
Kindly mark the answer as Correct & Helpful both such that others can get help.
Sandeep
Surbhi Srivasta
Hi Satish,
The following may help you resolve your query:-
https://community.servicenow.com/community?id=community_question&sys_id=74769d5bdba72050da1999ead39619ff
Please mark my answer Correct/Helpful, If it resolve your issue.
Surbhi
