Is there a way to disable a specific catalog from native view
Ray20
The catalog still needs to be accessible in the portal
9 REPLIES 9
Shivalika
Hello @Ray20
Hiding this particular item from the application or module itself.
Kindly mark my answer as helpful and accept solution if it helped you in anyway. This will help me be recognized for the efforts and also move this questions from unsolved to solved bucket.
Shivalika
My LinkedIn - https://www.linkedin.com/in/shivalika-gupta-540346194
My youtube - https://youtube.com/playlist?list=PLsHuNzTdkE5Cn4PyS7HdV0Vg8JsfdgQlA&si=0WynLcOwNeEISQCY
Ray20
Could you provide more detail on how you would do this?
Hello @Ray20
try creating user criteria with below 👇 script -
// Allow only when NOT in the platform for ITIL users
if (gs.hasRole('itil') && gs.isInteractive()) {
answer = false; // Hides from platform
answer = true; // Shows in portal or for non-ITIL users
It has is interactive - so I am assuming this won't work for platform but will give access in portal.
Try it and let me know.
Shivalika
brianlan25
So are you asking if you can hide a catalog item from the standard UI but still have it available in the portal? If that is the case I do not think it is possible. You can hide from the portal but I do note believe there is options for the standard UI.
Shivalika
Or @Ray20
You can write a Query BR and hide it from the catalog item list for them. But this has open ends if it accessible from anywhere apart from this list - maybe need to check that.
If both of these don't work, it means it's not possible to do.
Shivalika
