AutoPopulate a reference field based on another reference both fields referring same table
Need to auto populate application business unit which is a reference field referring (cmdb_ci_business_app) depending on the business application field which is also a reference field also referring to (cmdb_ci_business_app) table on a catalog form.
Variable 1: Business Application (Reference - cmdb_ci_business_app)
variable 2: Application business unit(reference-cmdb_ci_business_app)
tried the autopopulate option on the variable it is populating on form level but on ritm its clearing the value.
written a script include and onchange client script also
able to get the value from script include but not able to set on the field . Its setting the value and clearing immediately
please help
@Community Alums
For this case you can use 2nd variable as string type and populate the Business unit via onChange client script
15 REPLIES 15
Your issue is that both variables should not be referring to the same table.  For the value that you are returning from the modified Script Include, your reference table on the 'application_business_unit' variable needs to be the 'business_unit' table instead of 'cmdb_ci_business_app'.
