how can I set notification/system notification true from code (not ui by clicking)?
AlexandraSz
AlexandraSz
info: I need to send the emails using gs.eventQueue() -> but turning on notifications is not enough, system notifications must also be turned on
AlexandraSz
@AlexandraSz you can check the User Preferences, if you mark any of these Notification (or Display, Accessibility, ...) values, it's visible in that table.
Go to:
https://yourinstance.service-now.com/now/nav/ui/classic/params/target/sys_user_preference_list.do
Check the changes before or after you change any of the values, but it's not much easy to be honest
I did it, sorted the sys_user_preference table by both updated and created, but there is nothing related to this 😞
