Read and write access issue with Gitlab repos
Vengadesh
While trying to commit any updates to the repository, it throws an error stating " The user only has read access to the repo. Make sure the user has both read and write access". But I have enough permissions to read and write within repos.
Troubleshooted by creating a new access token with enough roles also but again it throws the same error
FYR:
9 REPLIES 9
Vengadesh
FYR: Had provided all the roles
are you able to amend changes with this user in gitlab ? (not from servicenow,)
Vengadesh
yes , able to update the changes in gitlab
The issue seems to be in servicenow then... can you check on servicenow account level ?
also can you check for logs?
Vengadesh
Not able to get you.Kindly provide your inputs
