copy comments from problem_task to problem and vice versa
tghadage124
Hi guys ,
i have requirement related to copy of work notes from problem to problem_task and vice versa ,
for copying from problem to problem_task its working here is the code :
its after update BR on problem table :
var problemTask = new GlideRecord('problem_task');
problemTask.addQuery('problem', current.sys_id);
problemTask.query();
if (problemTask.next()) {
    var workNote = current.work_notes.getJournalEntry(1);
    problemTask.work_notes = workNote;
    problemTask.update();
but to copy from problem_task to problem its not working here is the code :
while (problemTask.next()) {
    var workNote = problemTask.work_notes.getJournalEntry(1);
   // if (workNote) {
        current.work_notes = current.work_notes + '\n' + workNote;
        gs.info('Copied work note to parent problem: ' + workNote);
current.update();
can you please help me on this ?
thanks!!
Ankur Bawiskar
@tghadage124
the 2nd BR should be this
var problemRec = new GlideRecord('problem');
problemRec.addQuery('sys_id', current.problem);
problemRec.query();
if(problemRec.next()) {
        problemRec.work_notes = current.work_notes.getJournalEntry(1);
problemRec.update();
hi @Ankur Bawiskar ,
its still not working actually.
thanks!!
its working now but getting like this :
its getting repeated comments can you please help !
@tghadage124
check this link and it will tell solution on how to handle recursion
Sync'ing RITM and SCTASK work notes \ additional comments
