Cab Workbench DOUBTS AND MODIFICATIONS
03-26-2025 06:25 AM
This is the cab definition that i am using .
All the cab meetings are taking the same "Created" filter . I want the created filter to be changed dynamically , for example ..
There are 50 meetings , For 1st meeting we can have the same from cab definition . For next meeting the created before must be added with 7 days(19,26,2,9..) .Dynamically it need to change .How can i achieve this functionality ..
Also How can i make reject button on cab workbench to not work or completely remove it . Because it is not much needed.
Hitesh
03-26-2025 07:50 AM
Again, it's not possible. The workbench is not a form; it's a combination of UI pages, HTML, and CSS. Any changes to it are not easily doable. You can log a case with Now Support, and if the team has any workaround, will share with you.
