Not able to post a "Work Note" or "Additional Comment" when I change state to "Resolved" with New York Upgrade
01-21-2020 10:18 AM
We reccently upgraded to New York, and on one of our custom incident tables, we are unable to post a work note or additional comment when we change the state to "Resolved". Our additional comments section is required. If I add a comment and then use the "Save" UI Action at the top, the comment will post, and the "Post" button will then appear. The Post button hides as soon as the state changes to Resolved. Now I did find a similar post with someone that was having a similar problem, only his "work note" field was required. He also did not provide the resolution to his problem.
Here is the link to a similar issue:
Thanks!
01-21-2020 10:25 AM
01-21-2020 10:42 AM
Hello
Thanks for your response. Here is the patch info:
Build tag: glide-newyork-06-26-2019__patch5-12-24-2019
09-04-2022 09:40 PM
hi
