Rule entry under cmdb_ci_hardware identifier using non-existent table is ignored during identificati
edharris
Getting this error and I am not familiar on how to fix it. I went to the cmdb_entry_related table and the sys_object_source tables and could not find a record with the sys_id 73b8c48e8d707110f8778302d753bcd2 to delete. Open to any suggestions or if anyone has any workarounds. Thank you
12 REPLIES 12
Thanks, @sergiu_panaite!
For anyone else curious, we're running Yokohama Patch 1 and this workaround solution appears to have worked.
Will it still work if I deactivated the record instead of deleting it? Thanks
Brian Doyle1
Has anyone found a solution for this?  Did the workaround posted by Sergiu work for anyone else?
We just upgraded our dev environment to Yokohama Patch 1 and are seeing this intermittently when viewing incidents, changes, problems, etc.  Haven't been able to find a cause for this.
Hello Brian
I'm facing similar issue for change ..did you get any root cause for this ?
The workaround posted by Sergiu seems to have worked.  It was intermittently showing up.  Since I removed the file listed, we haven't had the error appear again.
Hope this helps.
Thanks!
