Need help to start creating my first catalog
amrsabil25
Greeting Dear Experts,
I had starting my learning journey later, and I asked for create a new catalog, but it's not created, could any one tell me why?
glideFather
Hi @amrsabil25,
can you please provide more details? this is very vague...
However, you created a catalog and it doesn't exist, or you had not sufficient rights?
Please describe step by step and eventually add screenshots.
If you have a catalog, it is important to associate it with a portal where it is expected to be visible.
Go to > Maintain catalogs:
Here you will either see it or not, then select the Catalog you want, scroll down and verify it has this set correctly:
Let me know if this helped you a bit
✂-----Cutting-out-the---✦AI-noise✦---All-replies-written-and-vouched-for-by-GlideFather---
This what appears to me, I don't know if I have the premotion to access the portal page or not?
Hi @amrsabil25
What Category you provided to your created catalog?
IT_test
