‎04-24-2023 11:43 AM
Hello All
I have an agile project that I want to separate the stories into buckets/workstreams (agile phases)
Currently all of the stories are all sitting under Agile Phase but I have separate workstreams with multiple stories for each and I think for project planning purposes I want to create a phase for each workstream ie Enable plugins,
Portal Integrations & Pubisher Packs, Entitlements, and entitlement inventory/license management
Software Models, Dashboards & Reports, Discovery, etc with the stories aliened in each
I created a Sampro plugin phase but i cant map the stories to that project task is that because its attached to the agile phase project task?
‎04-24-2023 03:13 PM
create separate phases for each go to Agile phase edit and remove those stories from AGILE phase re-map to each new phase created
