Business Rule keeps changing Project task state when Project state changes
Bob
Giga Contributor
I created a new Business Rule to prevent Projects being closed without closing the associated Project Tasks. The BR does stop the update from occurring, but the problem I am running into is that the Project Tasks are then all set to Closed Completed by some ninja BR or UI Action, which I am failing to find.
Things that I have tried:
  • Changing the order of my BR to 0 or 900, it didn't work.
  • I used the debugging tool and tried turning off every BR that I thought might be changing the state of the task to no avail.
  • Looked over all the UI Policies and Client Scripts finding nothing of use.
My overall goal for this change is:
When closing a project (State Change Closed Complete or Incomplete) - Using a BR to complete action
  Look at all the child Project Tasks
            If any project task has an open Time card
                      Stop check
                      Stop update
                      Reset State to previous
                      Alert user
            Else finish update of project
Might be an easier way of tackling this than a couple of BRs:
  1. Prevent closing project if open project tasks or time cards
  2. Prevent closing project tasks if open time cards
Ok, here's the full client script and script includes. It should be pretty easy to take the code you need:
Script Includes:
var ProjectUtilsAjax = Class.create();
ProjectUtilsAjax.prototype = Object.extendsObject(AbstractAjaxProcessor, {
      getOpenProjectTaskCount: function(parentID) {
              var projectID = this.getParameter('sysparm_project_id');
              var projectTaskCount = new GlideRecord('pm_project_task');
              projectTaskCount.addActiveQuery();
              projectTaskCount.addQuery('parent', projectID);
              projectTaskCount.query();
              return projectTaskCount.getRowCount();
      getProjectCounts: function() {
              var ptc = this.getRelatedRecordCount(projectID, 'pm_project_task', 'parent');
              var ic   = this.getRelatedRecordCount(projectID, 'issue', 'parent');
              var rc   = this.getRiskCount(projectID);
              var crc = this.getRelatedRecordCount(projectID, 'change_request', 'parent');
              var tcc = this.getTimeCardCount(projectID);
              var ed   = this.getEffortDeviation(projectID);
              var rp   = this.hasResourcePlans(projectID);
              var d = (ed > 10);
              gs.log("Variance:   " + d + " = " + ed);
              var relatedRecordCounts = {
                      "pm_project_task":ptc,
                      "issue":ic,
                      "risk":rc,
                      "change_request":crc,
                      "time_card":tcc,
                      "effort_deviation":ed,
                      "effort_deviated":d,
                      "open_resource_plan":rp
              return JSON.stringify(relatedRecordCounts);
      getRelatedRecordCount: function(projectID, tableName, fieldName) {
              var projectTaskCount = new GlideRecord(tableName);
              projectTaskCount.addQuery(fieldName, projectID);
      getRiskCount: function(projectID) {
              var riskGR = new GlideRecord('risk');
              riskGR.addQuery('state', '!=', 'closed');
              riskGR.addQuery('task', projectID);
              riskGR.query();
              return riskGR.getRowCount();
      getTimeCardCount: function(topTaskID) {
              var timeCardCount = 0;
              var projectRecords = new GlideRecord('planned_task');
              projectRecords.addQuery('top_task', topTaskID);
              projectRecords.query();
              while (projectRecords.next()) {
                      var timeCard = new GlideRecord('time_card');
                      timeCard.addQuery('state', '!=', 'Processed');
                      timeCard.addQuery('state', '!=', 'Approved');
                      timeCard.addQuery('task', projectRecords.sys_id);
                      timeCard.query();
                      var tcc = timeCard.getRowCount();
                      timeCardCount += tcc;
              return timeCardCount;
      getEffortDeviation: function(topTaskID) {
              var pu = new ProjectUtils();
              return pu.getEffortDeviation();
      hasResourcePlans: function() {
              gs.log("hasResourcePlans projectID:   " + projectID);
              var sysIDs = "";
              var projectGR = new GlideRecord('planned_task');
              if (projectGR.get(projectID)) {
                      gs.log("hasResourcePlans short_description:   " + projectGR.short_description);
                      var tree = new SNC.NestedIntervalUtilities("planned_task");
                      gs.log("hasResourcePlans tree:   " + tree);
                      var descendants = tree.getDescendants(projectGR, true);
                      gs.log("hasResourcePlans descendants:   " + descendants);
                      while (descendants.next()) {
                              sysIDs += ", " + descendants.sys_id;
              gs.log("hasResourcePlans sysIDs:   " + sysIDs);
              var resourcePlanGR = new GlideRecord('resource_plan');
              resourcePlanGR.addQuery("task", "IN", sysIDs);
              resourcePlanGR.addQuery("state", "!=", 7);
              resourcePlanGR.addQuery("state", "!=", 8);
              resourcePlanGR.query();
              if (resourcePlanGR.hasNext()) {
                      return true;
              return false;
      getTaskDescendants: function(task, sysIds) {
              var children = new GlideRecord("task");
              children.addQuery("parent", task.sys_id);
              children.query();
              while (children.next()) {
                      sysIds += ", " + children.sys_id;
                      sysIds = this.getTaskDescendants (children, sysIds);
              return sysIds;
      type: 'ProjectUtilsAjax'
Onsubmit Client Script on Project Table:
if(typeof gFormAlreadySubmitted == "undefined" ||   typeof gFormAlreadySubmitted == "null")
      gFormAlreadySubmitted = false;
function onSubmit() {
      if (gFormAlreadySubmitted)
              return true;
      // If not Close/Skip/Cancel then bail
      var state = g_form.getValue('state');
      if (state != 3 && state != -7 && state != 4)
              return true;
      // If New Record bail
      if (g_form.isNewRecord())
              return true;
      // Project sys_id
      var projectID = gel('sys_uniqueValue').value;
      // Open Risk/Issue/Change Request
      ga = new GlideAjax('ProjectUtilsAjax');
      ga.addParam('sysparm_name', 'getProjectCounts');
      ga.addParam('sysparm_project_id', projectID);
      ga.getXMLWait();
      var projectCounts = ga.getAnswer();
      var pco = JSON.parse(projectCounts);
      var ptc = pco['pm_project_task'];
      var ic   = pco['issue'];
      var rc   = pco['risk'];
      var crc = pco['change_request'];
      var tcc = pco['time_card'];
      if (ic != 0 || rc != 0 || crc != 0 || tcc != 0) {
              var msg = "The following records must be closed before the Project can be closed:\n";
              if (ic > 0)
                      msg += pco['issue'] + " Issues\n";
              if (rc > 0)
                      msg += pco['risk'] + " Risks\n";
              if (crc > 0)
                      msg += pco['change_request'] + " Change Requests\n";
              if (tcc > 0)
                      msg += pco['time_card'] + " Time Cards"
              alert(msg);
              return false;
      var ed = pco['effort_deviation'];
      var d   = pco['effort_deviated'];
      jslog("Variance:   " + d + " = " + ed);
      if (d || d == true || d == "true") {
              if (g_form.getValue('u_variance_explanation') == '') {
                      var msg = "Planned and Actual Effort has a variance " + ed +
                              "% which greater than 10%.   Please provide a Variance Explanation.";
                      alert(msg);
                      g_form.setVisible('u_variance_explanation', true);
                      g_form.setMandatory('u_variance_explanation', true);
                      return false;
      if (ptc > 0) {
              shouldProjectClose();
              return false;
function shouldProjectClose() {
      var dialogClass = window.GlideModal ? GlideModal : GlideDialogWindow;
      var dialog = new dialogClass('glide_confirm_standard');
      dialog.setTitle("Confirmation");
      dialog.setPreference('warning', true);
      dialog.setPreference('title', "All Open Project Tasks will close when the Project is Closed/Cancelled.   Proceed?");
      dialog.setPreference('defaultButton', 'ok_button');
      dialog.setPreference('onPromptComplete',   confirm.bind(this));
      dialog.setPreference('onPromptCancel', cancel.bind(this));
      dialog.render();
function confirm() {
      gFormAlreadySubmitted = true;
      if(g_form.getActionName() == 'sysverb_update_and_stay')
              g_form.save();
      else
              g_form.submit();
function cancel() {
      // Reset State to Original Value
      g_form.setValue('state', g_scratchpad.projectState);
kellykaufmann
Mega Guru
I'm not sure which version you are on or what your upgrade plan is, but note that in Helsinki they made it so you can do project & project task state customizations and removed some of the tentacles.
We are on Fuji and this just adds to the growing list of little tweaks and such that we should be on Helsinki.
