Collaborative Work Management Add reference to other Now Platform tables
Julie21
In ServiceNow docs, I can see that you can link to e.g. an incident from a Collaborative Work Management docs by using the / command.
Any idea which command to use if you're not using an English keyboard? I'm using a Danish keyboard and am not able to find any command that's working.
Collaborative documentation using CWM (servicenow.com)
Julie21
Yes, it unfortunately doesn't work either.
In the Washington Upgrade there's a shortcut to see all shortcuts available. On an English keyboard it's ctrl + /, while on a Danish keyboard it's ctrl + -
But unfortunately I haven't been able to find a similar workaround for the CWM.
