Display Info /Error message in Project Workspace on planning Console on update of any field
Khushboo8
I am trying to display a error message on change of any field on project task in below Planning View on Project Workspace but it is not coming  using a Business Rule . It works fine in native end though. Please find the below screenshot:
Business Rule Script : On update --Table Name : Pm_project_task
Script :
    // Add your code here
    gs.addInfoMessage('Test Message');
})(current, previous);
15 REPLIES 15
Vutikonda Vinay
UI policy with run script should be works other wise modify your business rule with this script
Type: Update
When to run : After
    // Skip if we're in a background operation or loading
    if (current.isNewRecord() || gs.getEventName() == 'async') {
    // Check if we're in a workspace context
    var isWorkspace = (typeof g_workspace !== 'undefined');
    // Get all changed fields
    var changes = current.getChanges();
    // If any fields changed
    if (changes && Object.keys(changes).length > 0) {
        var errorMsg = "Changes to project tasks require approval. Please submit a change request.";
Unfortunately this is not working 😞
Attila Beregvar
Have you found any solution to this since? I'm facing the same problem.
Hi @Attila Beregvar ,
Were you able to find a solution for this?
Vinay_97
Hi @Attila Beregvar,
As earlier I said that UI Policy with Runscript should works and now I have taken a scenario with it and it is working fine in My PDI.
Scenario: Here I used on Incident form Impact is 1-High as a trigger condition to show the Error Message on SOW Workspace
UI Policy
Run Script
Testing on SOW: When I change the Impact to 1-High shows me an error message
I believe that if SOW workspace is working fine it works on other workspaces too.
