How do I modify a Project Template?
andytom
Once a Project Template is created, how do we edit that template?  Or do we have to create a new Project from the Template, edit the Project and save as a new template?
Nicolas17
We are asking ourselves the same question... Has anyone found an answer?
If you're wanting to modify an existing template, navigate to Project Administration > Templates - Project and then select the template that needs editing.
Yes I know how to navigate in ServiceNow. Thank you.
Do you know how to insert a new project task in a project template?
the easiest way is to create a project
apply your existing template to the project
add a project task to the project
save the project as a (new) template
when you apply the new template to a project, it will have the task
