How to disable Classic project workspace from project workspace ?
VedhR
I have a requirement where in i need to disable the classic project workspace from project workspace, please refer to the attachment.
14 REPLIES 14
Just create it... it is not created by default in the upgrade process. Go ahead and create a new property, and set it to true.
Govardhan7
Hi @VedhR    Customers who upgraded from a version prior to the Xanadu release will not see this property enabled by default. To hide the classic workspace, they can manually create the property com.snc.project.disable_classic_workspace and set its value to true.
mikereaves
While that worked to remove the "Classic Project Workspace" from the Project Workspace, is there a way leave the "Classic Project Workspace" and remove the "Resources" link within the Classic Project Workspace ?  Thanks.
I have this exact same requirement, were you able to solve it?
mdalpi
You need to edit the Property "com.snc.project.disable_classic_workspace" and set it to true.
If this property does not exist, create one True/False in Global Application and set it to true.
