How to export ridac on project workspace
Hamza EL JIRARI
I am having probably a blank moment.
I can't find a way to export RIDAC records to Excel from the project Workspace RIDAC page. How can I do that?
BR,
Hamza.
Namita Mishra
Hi @Hamza EL JIRARI ,
Thanks for contacting the community.
I have created this short video to showcase the steps to export RIDAC.
From the project workspace export is not available but the list can be exported via the steps mentioned below.
Steps:
1. Open the project and select the related link - View RIDAC
2. From the column header, select export option to export the RIDAC list of that particular project.
Hope this answers the query, if it does please mark the response as correct answer.
Happy SPM Learning !
Thank You!
Namita Mishra
has this request been implemented? I would like to export from the project workspace the RIDAC records to excel.
Michelle Alexan
The export from View RIDAC only shows those RIDAC with a relationship, correct?  Or is there a way to update this list view to show all RIDAC?
