Is Top Project[Project] true not filtering out Sub projects in SPW
StephenPMO
I have a project with a sub project and it continues to show in SPW although I have added to the filter, Is Top Project[Project] is true.  Both projects still show in the prioritization list in SPW.
kaushal_snow
Hi @StephenPMO ,
Is Top Project field is typically utilized within the alignment planner workspace to differentiate between top level projects and sub projects. However, in SPW, the filtering mechanism may not automatically consider this field, leading to both projects being displayed....
To address this, you can create a custom logic in SPW that includes a filter condition for Is Top Project[Project] = true. This allows you to tailor the view to display only top level projects, excluding sub projects. Additionally, ensure that the Is Top Project field is correctly populated for your projects, as this will be essential for the filter to function as intended.......
If you found my response helpful, please mark it as ‘Accept as Solution’ and ‘Helpful’. This helps other community members find the right answer more easily and supports the community.
