Project Scheduling Engine
‎10-26-2015 01:02 AM
This post describes the behavior of the Project Scheduling Engine in the Fuji & Eureka releases. This post covers the following topics:
- Project Schedule
- Time Constraints
- Dates & Duration
- Relations
All examples in this post assume use of the out-of-box Project Management Schedule.
Project Schedule
In ServiceNow, schedules are rules that include or exclude time for various actions or tasks. The Project Management application ships with a schedule Project Management Schedule, which specifies a 40-hour workweek.The durations specified in projects and project tasks take the schedule into consideration. So, for instance, a task planned duration of 1-day means 8 hours of work. Conversely, if you create a task with 8 hours of duration, it would be saved as a 1-day task. To understand this behavior, consider the following examples:
| Input duration | Eventual duration (after recalculations for the schedule) |
| 8 hours | 1 day |
| 12 hours | 1 day 4 hours |
| 1 day 8 hours | 2 days |
The project schedule engine always computes a duration based on the schedule specified in the Project record rather than the value in the Planned duration field. The other aspect to consider is the schedule entries associated with the schedule. For example, the Project Management schedule that we ship has two schedule entries:
- Monday-Friday 8AM-12PM
- Monday-Friday 1PM-5PM
This has an impact on the end date calculation of a task given its start date and duration. Consider the following examples:
# | Planned Start | Planned Duration | Planned End |
1 | 2015-09-08 08:00:00 | 1 day | 2015-09-08 17:00:00 |
2 | 2015-09-08 08:00:00 | 5 hours | 2015-09-08 14:00:00 |
3 | 2015-09-11 08:00:00 | 2 days | 2015-09-14 17:00:00 |
For #1, we have a task with a duration of one day. It starts at 8AM on a work day and ends at 5PM on the same day.
For #2, we have a task with a duration of five hours. It starts at 8AM, but the end is set to 2pm instead of 1pm, because the schedule specifies a break from 12PM to 1PM.
For #3, we have a task with a duration of 2 days. It starts on a Friday, so the end date is set to the Monday of the following week. The schedule specifies Saturday and Sunday as holidays, so these days are not included in the work week.
Time Constraints
A Time Constraint is a restriction on a project task that determines when the project should start. The following two types of time constraints are supported:
Start ASAP — The task is set to start ASAP.
Start on specific date — The task is set to start on a specific date.
The following examples explain how time constraints affect the start dates of tasks.
Consider the following project structure.
# | Task | Time Constraint | Planned Start | Parent |
1 | Project | 2015-09-08 08:00:00 | -- | |
1.1 | Task 1 | Start ASAP | 2015-09-08 08:00:00 | Project |
1.2 | Task 2 | Start on | 2015-09-10 08:00:00 | Project |
Then, the following scenarios demonstrate how time constraints affect the derivations of the planned start dates.
Task | Parent | Time Constraint | Planned Start |
Task 3 | Project | Start ASAP | 2015-09-08 08:00:00 |
Task 4 | Task 1 | Start ASAP | 2015-09-08 08:00:00 |
Task 5 | Task 2 | Start ASAP | 2015-09-10 08:00:00 |
When Task 3 is added under Project with the time constraint Start ASAP, the planned start date of Project is set as the planned start date of Task 3.
When Task 4 is added under Task 1 with the time constraint Start ASAP, the planned start date of Task 1 is set as the planned start date of Task 4..
When Task 5 is added under Task 2 with the time constraint Start ASAP, the planned start date of Task 2 is set as the planned start date of Task 5, because that is the earliest that Task 5 can start.
If a task is created at any level with the time constraint Start on, the planned start date of the task can be set to anything on or after the Project start date. For example, in the above project structure, you cannot add a task with the time constraint Start on and the planned start earlier than 2015-09-08 08:00:00.
Automatic change of time constraint on a task
When children tasks are added to a task in a project, the time constraint of the task becoming parent is automatically set to Start on a specific date. In the above example, when Task 4 is added to Task 1, time constraint of Task 1 is changed from ASAP to specific and then the Task 1 Start date cannot be changed. To understand the behavior, consider the following example.
Consider a Task with the time constraint Start ASAP.
Task | Start ASAP | 2015-09-08 08:00:00 |
Consider adding the following task Task 1 as a child task to Task.
Task 1 | Task | Start ASAP | 2015-09-08 08:00:00 |
Then, Task is modified as follows (the time constraint is changed):
Task | Start on | 2015-09-08 08:00:00 |
Consider adding the following task Task 2 with the time constraint Start on as a child task to Task.
Task 2 | Task | Start on | 2015-09-06 08:00:00 |
Then, Task is modified as follows (planned start date is changed):
Dates & Duration
We have two sets of dates in Project and Project Tasks. One is the planned start date, planned end date and other is the actual start date and actual end date. Depending on the state of the project & task the planned or actual values are populated.
Planned Start Date
The following table includes different scenarios for the setting of default start dates for a project and its tasks.
Scenario | Planned Start Date |
Project is created | The default start date of the project is 08:00: 00AM on the next working day |
Task is created with with the time constraint Start ASAP | The default start date of the task is the same as the start date of the project |
Sub-task is created with the time constraint Start ASAP | The default start date of the sub-task is the same as the start date of the parent task |
Start date of sub-task is changed | The start date of the parent task is changed to the start date of the sub-task |
Note: If a task has multiple sub-tasks, the start date of the task is the same as the earliest start date of the children tasks.
Planned start date of a project or a task can be modified if the project or the task does not have any children. If a project or a task has children, the earliest planned start date of the children is set as the planned start date of the project or the task.
Planned End Date
For a project or for a task in the project, the planned end date is calculated using the following formula:
Planned End Date = Planned Start Date + Planned Duration
This formula is applicable only when the task or the project is in the pending or the open state. When the task moves to the work in progress state, the actual start date gets populated. For a task that is in the work in progress or the closed state, the planned end date is calculated using the following formula:
Planned End Date = Actual Start Date + Planned Duration
The planned end date of a project or a task can be modified if the project or the task does not have any children. If a project or a task has children, the latest planned end date of the children is set as the planned end date of the project or the task.
Actual Start Date
When the state of a project or a task changes to the work in progress state, the current time is set as the actual start date of the project or the task. The actual start date can be edited and set to a new value until the task remains in the work in progress state.
The actual start date of a project or a task can be modified if the project or the task does not have any children. If a project or a task has children, the earliest actual start date of the children is set as the actual start date of the project or the task.
Actual End Date
When the state of a project or a task changes to the closed state, the current time is set as the actual end date of the project or the task. The actual end date can be edited and set to a new value until the task remains in the closed state. The actual end date is calculated using the following formula:
Actual End Date = Actual Start Date + Actual Duration
The actual end date of a project or a task can be modified if the project or the task does not have any children. If a project or a task has children, the latest actual end date of the children is set as the actual end date of the project or the task.
Planned Duration
Planned duration is calculated using the following formula:
Planned Duration = Planned End Date — Planned Start Date
Any change in the planned duration of a task affects the planned end date of the task. The planned duration of a project or a task can be modified if the project or the task does not have any children.
Let us now see the impact of editing of each of those dates and duration fields for various task states — what changes it will cause
Task State | Edit Field | Field Recalculated |
Pending/Open | Planned Start Date | Planned End Date (Planned Start Date + Planned Duration) |
Pending/Open | Planned End Date | Planned Duration (Planned End Date - Planned Start Date) |
Pending/Open | Planned Duration | Planned End Date (Planned Start Date + Planned Duration) |
Work in progress/Closed | Planned Start Date | No impact |
Work in progress/Closed | Planned End Date | Planned Duration (Planned End Date - Actual Start Date) |
Work in progress/Closed | Planned Duration | Planned End Date (Actual Start Date + Planned Duration) |
Work in progress | Actual Start Date | Planned End Date (Actual Start Date + Planned Duration) |
Closed | Actual Start Date | Planned End Date (Actual Start Date + Planned Duration) |
Task Relationships
Project Management supports one type of relationhip between tasks: Finish-to-Start.
Consider these tasks:
Task | Time Constraint | Planned Start Date | Planned End Date |
Task 1 | Start ASAP | 2015-09-10 08:00:00 | 2015-09-10 17:00:00 |
Task 2 | Start ASAP | 2015-09-01 08:00:00 | 2015-09-01 17:00:00 |
Adding a relation from Task 1 to Task 2, which makes Task 2 the successor in the relationship: recalculates Task 2's planned dates as follows:
Task | Dependency | Time Constraint | Planned Start Date | Planned End Date |
Task 1 | Start ASAP | 2015-09-10 08:00:00 | 2015-09-10 17:00:00 | |
Task 2 | Task1 | Start ASAP | 2015-09-11 08:00:00 | 2015-09-11 17:00:00 |
If Task 2 has a Start on time constraint instead of a Start ASAP time constraint, Task 2's planned dates do not change.
Task 2 | Start on | 2015-09-01 08:00:00 | 2015-09-01 17:00:00 |
- 6,703 Views
‎11-04-2015 12:11 PM
This is very helpful, thank you for posting it!
‎06-28-2016 11:01 PM
Does this applies to the Geneva version too?
‎06-28-2016 11:12 PM
You can read about Geneva (onwards) behavior in this post - Project Scheduling Engine - Geneva
‎06-29-2016 08:46 PM
Thank you, Balaji.
We have issue with the Planned End Date (of task/sub project) changed to a diff date after approval and still trying to figure out what happen to it.
