Survey Management/Assessment Instance Questions
Dan Brown2
I have created a survey with questions using the data type Choice.   The Assessment Metric Definitions have a Display and Value (the value being numerical).     When a person completes a survey it can be found under the Assessment Instance, with the questions/answers under the Assessment Instance Questions, the Choice is found under the Value column, but is only represented by the numerical Value field.
How can I report or even view the Display value of the Choice answer, other than go back into the question and view the choices?
Cheers,
Dan
kevclark
Tom's suggestion isn't bad, however the Metric Result table isn't visible to an itil user who has submitted the assessment the same way the Assessment Instance Question table is, so you'd have to additionally fiddle with the ACLs on Metric Result to grant this access I think.
