Assessment Simulator Task 3 – Add and Post Comment Validation Issue
06-28-2026 08:48 AM
I'm facing an issue with Assessment Simulator Task 3. I created the incident, added the required customer-visible comment, clicked Post, and confirmed the comment appears in the Activities section. However, the task still fails with the message "Did you add and post a comment?" even after trying in a new instance.
Could you please help?
06-28-2026 09:03 PM
Hi @srilekha090
If Validation task is failed , for my case, I have seen always- a step has been missed or not configured properly at my end.
If you think you have done it correctly as per video but for them validation passed but your case validation failed,
Raise a case with Now learning support within ServiceNow university.
https://learning.servicenow.com/lxp/en/pages/now-learning-help-center?id=nl_kb_home
Note: Ensure you have done /tried every steps correctly.
07-01-2026 07:23 AM
I have tried again after terminating the instance. After taking new instance it finally worked.
08-28-2026 03:42 AM
I terminated my instance and did a refresh one, I made sure I saved the incident and it worked
