Flow Triggers after the REQ approval
SN2024
I created a new catalogue item and new flow. New flow only triggers on RITM level instead of REQ level.
REQ level goes to approval group but I don't need approval for this catalogue item.
I have action setup in the flow-  Update Record to Trigger " Service Catalogue>Requested item record>request"  with fields:
Approval - Approved
and it's still not setting REQ to auto Approved state and shows error on Test: "Value of field record is not a GlideRecord"
Can someone advise how can I skip this one item from going through the approval process on REQ level and set it to approved?
Thank you in advance for your help.
@SN2024
check this BR -> Cascade Request Approval to Request Item is active or not
