ā07-04-2024 08:45 AM
i recently completed System administration course and want to do capstone project challenge ,
can any one please guide me through?
ā07-04-2024 02:54 PM
Hi @POLAMSAI
To do a capstone project, you must receive the instructions in your course,
You can request for the instance.
and then follow the lab instructions and do the project.
It is easy and I am sure you can do it quickly.
ā07-19-2024 03:34 AM
Atul, I was able to figure it out. You need to access the Instance access menu, changer user role.
I was going through my profile which did not work. I appreciate your reply anyway.. TY
ā09-01-2024 01:00 AM
I have completed my CSA fundamentals course. I want to do a Capstone project. But where can I find the tasks from the project? Are the tasks given in the course are the capstone tasks?
ā05-24-2025 12:20 PM
There is within the SNAF Course Lab Files, there should be a zip file named OneDrive, that you must have downloaded. The capstone project files are inside, it's PDF file containing instructions and solutions.
