Reference qualifier advance
tylerduren7
Create a catalog item withe following details:
Item name : Add User to a Group
Variables:
1. Please select the user. ( it should show list of all the active users so that we can select one )
2. Select the Group. ( it should be showing all the active groups where the user is not already member of it )
Please give me solution for this
Ankur Bawiskar
@tylerduren7
do this
1) 1st variable add this reference qualifier -> active=true
2) add this in 2nd variable ref qualifier
javascript:'sys_idNOT IN' + new global.ArrayUtil().convertArray(gs.getUser().getUserByID(current.variables.firstVariable).getMyGroups());
16 REPLIES 16
Sunny3008
Hello @tylerduren7 ,
1. For user variable use advance reference qualifier
active=true
2. for group variable use advance reference qualifier
sys_idNOT INjavascript:gs.getUser().getMyGroups()
replace ":" with ":" in query.
If my answer helps you mark this as correct and helpful.
Sunny
you can try like following which is worked for me.
sys_idNOT INjavascript:gs.getUser().getUserByID(current.variables.please_select_user).getMyGroups();
replace :  with ":"
Sunny R
Screenshot 2025-06-19 115426.pngScreenshot 2025-06-19 115443.pngScreenshot 2025-06-19 115501.png
Didn't work where user George is already in four groups still reflecting 51 groups
Chaitanya ILCR
Giga Patron
Hi @tylerduren7 ,
on the 1. please select the user variable add filter like this
on the 2. Select the Group
javascript:'active=true^sys_idNOT IN'+Array.from(gs.getUser().getUserByID(current.variables.please_select_the_user).getMyGroups())
it's javascript:  not javascript:
refer the screenshots
Note: in the above line update(please_select_the_user ) with the name of 1st variable (please select the user) if the name is different
Incase of any issues please share screenshots of your variable records
share 4 screenshots 2 for question section's
2 of Type specifications section's
Chaitanya
