‎04-04-2025 09:31 PM
I have enrolled into certified system adminstration course and i got lab instance.
Now can i enroll into another course and request lab instance and work on both instances concurently.
‎04-06-2025 09:58 PM
Yes, you can enroll in another course and request a separate lab instance for it. Each course that includes a lab typically provides its own unique instance, and you are allowed to work on multiple instances concurrently.
However, keep in mind:
You’ll need to manage your time and focus effectively across both instances.
Make sure each instance is used only for the corresponding course tasks, as mixing configurations between courses may cause issues.
Also, confirm the expiration dates of each instance, since they may be different.
‎04-06-2025 03:21 AM
Hi @Shivalika
Yes, also if she enrolls in another course, the system notifies that she already has a lab instance. It will either release that instance or allow her to use the same one. I had this experience, but it might change now.
Also, as you mentioned, and based on my limited knowledge, you need to release the previous instance of the same course to get a new one. This means a single course can have a maximum of 8 instances, but you can't get two instances of the same course. However, you can use the same instance for two different courses.
@Sasipreetham If still doubt, log a now learning case.
‎04-06-2025 08:54 PM
Hello @Sasipreetham
Please confirm if you checked my answer. Kindly mark my answer as helpful and accept solution if it helped you in anyway. This will help me be recognized for my efforts and also it can move from unsolved bucket to solved bucket.
Shivalika
My LinkedIn - https://www.linkedin.com/in/shivalika-gupta-540346194
My youtube - https://youtube.com/playlist?list=PLsHuNzTdkE5Cn4PyS7HdV0Vg8JsfdgQlA&si=0WynLcOwNeE
