Preparing for CAD Certification – Need Study Materials & Tips
priyanshube
Hello everyone!
I’m very happy to share that I’m currently preparing for the CAD Certification exam, and I’m hoping to get some guidance from this community.
While going through different forums and websites looking for study guides and resources, I’ve noticed that a lot of what’s available is either outdated, incomplete, or not aligned with the current exam objectives. Because of that, I’m starting to build my own notes and flashcards — but before I go too far, I thought I’d reach out here.
If anyone has:
  • Updated study materials or checklists for the current CAD exam
  • Flashcards or question banks they’ve used successfully
  • Tips on how to structure preparation (timelines, practice tasks, key domains)
  • Any recommended courses, labs, or practice exams
…I’d be very grateful if you could share them!
My goal is to create a comprehensive reference set aligned with the official exam blueprint and then share it back here for others who are preparing too.
Thanks so much in advance for any help or guidance you can offer! 😌
2 ACCEPTED SOLUTIONS
MansiM
Great to see your interest in the CAD. I recently passed CAD exam successfully.
Here's some points you can consider:
1. Go through the "Scripting in ServiceNow" and "Application Development Fundamentals" courses. (They are included with training subscriptions.)
2. Try building simple apps in your PDI (Personal Development Instance). For example, Create tables, forms, UI Policies, Client Scripts and access controls. - These are directly tested in the exam.
3. Focus on data schema, business rules, client scripts, flow designer and application security - These are high-weighted areas.
4. Create flash cards for Glide APIs, dictionary attributes and roles.
5. Review common scripts (Glide Record, GlideAjax, GlideForm).
Preparation Strategy:
  • Spent at least 2-3 weeks with daily practice in your PDI.
  • Break prep into domains:
    • Application User Interface and Security
    • Application Automation
    • Application Development
    • Designing and creating application
  • You can find unofficial practise questions on some forums (Exam topics, UDEMY) but rely more on your hands-on practice since the exam tests applied knowledge.
  • Finally join discussions here and ask doubts- community is super helpful.
You're on the right track by making your own notes and flashcards.
Good luck, you'll do great.
If my response proves useful, please indicate its helpfulness by selecting " Accept as Solution" and " Helpful." This action benefits both the community and me.
Mansi Mehta
Linkedin: https://www.linkedin.com/in/themansimehta
228w1a4248
Giga Expert
Hello there,
If you are preparing for the CAD exam, I recommend reading the ebook and then referring to these MCQs, which will help you understand how well you have prepared for the exam.
vinaykpro.github.io/ClearCad-Dump_Quiz
If my comment helped, mark it as a solution so that this can help others.
You can take reference, but there are also few new major concepts that were not covered in this and could come up in the exam.
MaryNita
Giga Contributor
I’m thrilled to be part of this discussion. Many users have shared valuable insights based on their own experiences and knowledge. I’d also like to share a few preparation tips from my side:
  • Start with the official ServiceNow CAD Documentation and complete the core Now Learning courses.
  • Build small custom apps, review Glide APIs, ACLs, and follow a structured 4-week study plan.
  • After completing official training, you can validate your skills using CAD Practice Tests.
Consistent practice and real-world application are the keys to success.
Roger11
Giga Guru
Though to visualise how to answer questions that are posed as below - it doesn't really add value to the certification as it needs you to focus on how you drink the ServiceNow Kool Aid compared to working with the basic use cases of adding and removing fields and formatting form layouts. If your brain is at all distracted by how other platforms or applications work, it's really easy to come up with the wrong answer without necessarily making you a worse developer, particularly with AI making inroads.
Which of the following statements is true for the Form Designer?
a) To add a field to the form layout, drag the field from the Fields tab to the desired destination on the form.
b) To create a new field on a form's table, drag the appropriate data type from the Field Types tab to the form and then configure the new field.
c) To remove a field from the form layout, hover over the field to enable the Action buttons, and select the Delete (X) button.
d) To add a section to the form layout, drag it from the Field Types tab to the desired destination on the form.
