Flow Designer Not Triggering Approval for Requested Item in Demo Instance
asadmansoor
Hi all,
I’ve created a Flow Designer flow to trigger an approval request to the manager of the "Requested For" user in a Service Catalog item.
The flow is working perfectly in my PDI instance — it creates the Requested Item and sends the approval to the manager as expected.
However, when I move the same flow to my Demo instance:
  • The flow is not consistently triggering on item submission.
  • The Requested Item is getting created, but in most cases, the approval is not sent.
  • Sometimes it works, but most of the time it doesn’t.
I’ve checked:
  • The "Requested For" users have managers set.
  • The flow is active and attached to the correct Catalog Item.
  • The trigger is set to "Service Catalog → Requested Item".
Is there any known issue with flow triggers in Demo instances? Or is there something I might be missing (e.g., timing issues, access, cache, ACLs, etc.)?
Any help or suggestions would be appreciated.
Thanks in advance!
@asadmansoor
that's the issue.
Since REQ is not approved the RITM flow didn't trigger.
Did you check the link I shared?
Did you approve REQ and see if flow triggered or not?
