Flow Designer showing empty runtime values for different fields after Xanadu Update
11-12-2024 11:31 AM
Recently our instance was upgraded to the Xanadu version but after that the Flows are not working correctly. The value of some fields of trigger record in some actions are coming as empty even though I know they are not empty.
At the first step, there is a subflow which is updating a field on the trigger record, there is a wait until completion condition for that step. After the first step, the next few steps are if and if else condition related to the field which is modified in step 1, but the if and if else conditions are failing because they are showing empty runtime value for that field. This doesn't used to occur earlier, it only started after the Xanadu update. This is just 1 example, this issue is occurring for other fields as well which I am modifying as part of this flow. When I look at the XML of the record, I can see the fields are not empty.
06-26-2025 10:58 AM
The only thing that worked for us was reverting back the flows to engine major version v1, after xanadu/yokohama upgrade, flows were updated to engine major version v2.
02-11-2026 12:07 PM
Running into the same issue here. Could you share the PRB number for the problem they created?
08-11-2026 10:42 AM
Can you please checked if "changed Fields" object is giving you data in your flow?
It could be that you are impacted as explained in following article & importing FDCollection record from lower environment where flow works or from OOB instance would fix the issue -
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB2430131
Thanks & Regards,
HSB
