Issue with Remote file import after washington upgrade
Sangeetha Harin
Hi Everyone,
We are using Remote file import to fetch the csv file from Mid-server and processing the record to update user table. It stopped working after washington upgrade. Getting the below error.
var remoteFileImport = new CSMIDServerRemoteFileImport();
remoteFileImport.getRemoteFileAndUploadToInstance()
Root cause of JavaScriptException: java.lang.IllegalAccessException
Any lead will be really helpful.
napatil24
Update the MID server Wrapper file with Below 2 line
in file ---  agent/conf/wrapper.conf file
---------------------- Below 2 line add --------------------------------------
wrapper.java.additional.201=--add-opens=java.base/sun.net.www.protocol.https=ALL-UNNAMED
wrapper.java.additional.202=--add-opens=java.base/sun.net.www.http=ALL-UNNAMED
26 REPLIES 26
Uncle B
Facing same issue but even with adding the two lines, error remains. Any other things to look out for?
Hope you restarted the services. We have added those lines and restarted the service, nothing else was done. Our issue resolved.
Yes, I did restart the mid-server. Should the box be restarted as well?
Also, make sure you are working with the correct Midserver that matches the instance you are testing -- I made the mistake of editing the wrong midserver first. Did you make the change in the override CONFIG file?
Yes, and the changes were made to the config file.
