Issue with Remote file import after washington upgrade
Sangeetha Harin
Hi Everyone,
We are using Remote file import to fetch the csv file from Mid-server and processing the record to update user table. It stopped working after washington upgrade. Getting the below error.
var remoteFileImport = new CSMIDServerRemoteFileImport();
remoteFileImport.getRemoteFileAndUploadToInstance()
Root cause of JavaScriptException: java.lang.IllegalAccessException
Any lead will be really helpful.
napatil24
Update the MID server Wrapper file with Below 2 line
in file ---  agent/conf/wrapper.conf file
---------------------- Below 2 line add --------------------------------------
wrapper.java.additional.201=--add-opens=java.base/sun.net.www.protocol.https=ALL-UNNAMED
wrapper.java.additional.202=--add-opens=java.base/sun.net.www.http=ALL-UNNAMED
26 REPLIES 26
I did - but I will try again
Still no luck
scottangehr
Giga Guru
Did the midserver need to be restarted or revalidated?
Yes, restarted mid server. What error are you seeing in ecc queue?
I'm not seeing any ecc queue or any logs for this, unless I'm not looking in the right spot
