Problem and Change Management missing in ServiceNow Brazil PDI
kavik
Issue: Problem and Change Management Missing in ServiceNow Brazil PDI
After working with a newly provisioned ServiceNow Brazil PDI, I noticed that certain ITSM functionalities were missing.
Observed Issues:
• Problem and Change Management modules were missing from the Application Navigator.
• The problem_id, rfc, and caused_by fields were missing from the Incident form.
• These fields were also unavailable in Form Layout.
Initially, I investigated the Incident dictionary, suspecting that the OOB field definitions were missing.
Possible Resolution:
The application Service Operations Workspace ITSM Advanced Applications (sn_sow_itsm_adv_ct) needs to be installed to enable the relevant advanced ITSM capabilities in affected instances.
This is particularly relevant for developers working with freshly provisioned Brazil PDIs.
Sharing this finding to help other ServiceNow developers avoid unnecessary troubleshooting and manually recreating OOB fields.
#ServiceNow #ServiceNowPDI #ServiceNowDeveloper #ITSM #ProblemManagement #ChangeManagement #BrazilRelease #NowPlatform #ServiceOperationsWorkspace #ServiceNowCommunity
Tanushree Maiti
Hi @kavik
Please tag it as article.
Also mention , in PDI, version 9.1.1 or lower version needs to install as higher version (>9.1.1) is having dependencies which can not be installed in PDI.
