Flow designer
saikumarkak
I have a table API from client I wall to call that API through GET method in my servicenow instance. Here I want to call that through flow designer with passing one field as unique I'd because to avoid the duplicate records how can I achieve this from flow designer to call this flow designer for every 30 minutes.
Shree_G
Hello @saikumarkak ,
Below video reference will help with your concern.
https://www.youtube.com/watch?v=Io5TtlAVY54&t=262s
In this video, we show an alternative to scripted REST APIs using a REST API triggered flow to make inbound integrations easier to maintain. Links: Docs: REST API Trigger (Rome): ...
saikumarkak
@Ankur Bawiskar ,
can you please provide the total process for get method to check my flow designer
@saikumarkak
the links I shared should help you.
As per new community feature you can mark multiple responses as correct.
REST step
Outbound REST integration using flow designer
If my response helped please mark it correct as well so that it benefits future readers.
saikumarkak
@Ankur Bawiskar
here basically i didn't write any  scripted rest api. here the requirement is totally the work should be done in flow designer what ever we do.
