07-31-2026 08:09 AM
Hi Team,
Infrastructure Required is yes, then new task should create , the infrastructure is updated in the sc task variables only.we are using the flow desiner
08-03-2026 05:24 AM
are you sure the variable has value as yes when your flow checks it?
08-03-2026 09:29 AM
Hi @avinash1289 ,
You selected the First step Get Catalog Variable. You need to select the if above step get catalog variable for fetching updated values.
08-03-2026 05:29 AM
yes, it is drop down only
