Unable to edit flow - Flow has been modified since you opened it" after page refresh
omkar shinde
Hi everyone,
I’m encountering a persistent issue in Workflow Studio / Flow Designer (Zurich Patch Update).
The Issue: Every time I create a new flow and perform a hard refresh of the browser tab, the flow becomes non-editable. I receive a pop-up modal stating:
Steps to Reproduce:
  • Create a new Flow in Workflow Studio.
  • Add a Trigger (e.g., Service Catalog) and one Action.
  • Perform a browser hard refresh (Ctrl+F5).
  • Upon reload, the "Unable to edit" modal appears. Even after closing it, the flow remains stuck or requires multiple reloads to become editable again.
What I've Checked:
  • I am the only person working on this flow (no concurrent users).
  • I do not have the same flow open in multiple tabs.
  • Clearing browser cache didn't resolve the persistent state of the error.
Has anyone encountered this sync issue recently? Is there a specific system property or background job (like flow compilation) that might be locking the record and causing this "modified" mismatch?
Any insights or workarounds would be greatly appreciated!
Josh Pirozzi
Hey @omkar shinde,
Have you also checked if your Flow is referencing a Catalog Item Variable that may have been changed? I know you mentioned that this is impacting your Catalog Items globally, but it's possible you have either a Varible or Variable Set that was modified and will throw an error when trying to access Flows.
IE: You have an IF Action referencing a now inactivated option in a Select Box.
