Manually closing a case and terminating open playbook
Kit G
Giga Guru
Hi all,
Looking for some advice on handling manual case closure and playbook termination.
Scenario
Currently we have a custom case which has an associated playbook that triggers on creation. The playbook when completed successfully closes out the case and all is well. However if a agent sets the case to a resolution of cancelled for example the playbook remains active and the case remains in an open state.
Questions
  1. What are the best practice methods for controlling manual case closure?
Thanks in advance
Hi @Lisa Holenstein ,
We ended up using a business rule and scripting to resolve this issue which was fairly straight forward. Understanding not all playbook users may be familiar with scripting it. Thanks again for your input 😄
Sample
sn_playbook.PlaybookExperience.cancelPlaybooksByParentRecord(current, "XYZ is cancelled");
Doco
PlaybookExperience | ServiceNow Developers
Cheers
Kit
Hi @Kit G !
Thanks for updating this with your solution! 😊
Hi Lisa, All,
I just tried your suggested solution to end the playbook (after a rejected approval) but it doesn't work. I can add your suggested action "Cancel remedial action playbook". I fill in the cancellation reason ( parent record - close notes. I don't see any other required field. Still when i wanna activate the playbook i got error "missing required field" that points to my action. What i'm doing wrong ?
Greetings Alex
