App Engine STudio Workspace Not Loading Home Page
Felipe Albino
I created a custom app using AES and configured a Workspace. The Workspace is pretty standard, has a Home and a Lists tab.
When I deployed it to my Test environment, everything on the Scoped App got moved up... but there is only one issue: the Home page of the Workspace does not load. The Lists view works fine, but the Home page with the reports is stuck.
I thought that something must of gone wrong when I initially create the Workspace, so I created a new Workspace and delete the old one. Promoted the application to my Test environment, and again the Home page does not load.
I am unable to manage or view any details of the Workspace in my Test environment because the Workspace record itself does not show up in the Workspace Experience module.
Has anyone run into this issue or know a way around this? I can't edit or do any changes to the Workspace in the Test environment because it was developed in Dev. When I open AES in my Test environment, the Application is not available.
Felipe Albino
Updating this thread with the issue and fix we found:
When our application got moved to the test environment via the Pipeline deployment, the PAR Dashboard did not bring the PAR Dashboard Permissions or User Metadatas with it.
So we had to manually export and import those permissions and matadatas in our upstream environments to make the Workspace work again.
I hope this helps anyone that runs into this issue.
Thank you so Much! This solved my issue.
