Calculating values of field automatically
SAM321
Hi all, so i have 4 fields in form like,
Unit price - 5000
Quantity - 6
discount - 10%
when i fill this fields
Total price field should be filled automatically...How to achieve this
@SAM321 you should right click on unit in your form and see the field name and that names of other fields respectively should be changed in the script in order to make it work.
9 REPLIES 9
SAM321
@aditya174 its not working
@SAM321 , you need to replace the getValue() parameter with your field's backend name this code won't work if you use it directly, kindly try to replace the parameters or share them here with me so that I can change it for you.
Aditya
SAM321
Screenshot (81).pngScreenshot (82).pngi shared form view and script sir @aditya174
SAM321
@aditya174 does this script work , if the field id( price field type)
