Flow designer error: Unable to load connection with alias ID for DocuSign
06-01-2025 06:33 PM
We are trying to use DocuSign spokes in flow designer and we are encountering "Unable to load connection with alias ID" error. The flow already runs as system user. Unable to verify what connection alias record it is using since in the flow execution logs it shows empty target.
Unable to load connection with alias ID: <a href="/sys_alias.do?sys_id=" target="blank">Open Connection Alias</a>Any of you have same experience and what did you do to fix this?
Thanks!
06-01-2025 07:12 PM
Hi @ryev_a_
please check if the mitigation steps described in https://www.servicenow.com/community/developer-articles/troubleshooting-flow-designer-quot-error-whi... will help.
Maik
06-01-2025 08:58 PM
did you verify the connection is working fine before using in flow?
06-03-2025 06:30 PM
Yes we actually got successful connection configured. Only encountered the connection alias error in flow designer when the flow is triggered.
06-03-2025 06:31 PM
Thanks, quite a list, we need to check this.
