Glideajax script include
MohdF
Hi all,
When I am trying to auto populate caller's email, location and manager in the incident after changing the caller, it is auto populating the email and manager's field but not the location field, I am using client scripts and script include for this
This is my client script
	var caller_details = g_form.getValue('caller_id');
	var ga = new GlideAjax('AutoPopulate_CallerInfo');
	ga.addParam('sysparm_name', 'getCallerInfo');
	ga.addParam('sysparm_value', caller_details);
	ga.getXML(callback);
	function callback(response){
		var test = answer.split(',');
		g_form.setValue('u_email_id', test[0]);
		g_form.setValue('u_caller_s_location', test[1]);
		g_form.setValue('u_caller_s_manager', test[2]);
and this is my script include
var AutoPopulate_CallerInfo = Class.create();
AutoPopulate_CallerInfo.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    getCallerInfo: function() {
        var sysIdofcaller = this.getParameter('sysparm_value');
        var x = new GlideRecord('sys_user');
        x.addQuery('sys_id', sysIdofcaller);
        x.query();
        if (x.next()) {
            return x.email+','+x.location+','+x.manager;
        return '';
    type: 'AutoPopulate_CallerInfo'
 Please help! anyone!
@MohdF ,
what type of field you have used for Callers location ? and are you referencing it to cmn_location table or not ?
please put an alert and check what you are getting ?
Please mark this comment as Correct Answer/Helpful if it helped you.
Swathi Sarang
Swathi Sarang
12 REPLIES 12
I am getting the sys_ID of the location
@MohdF  but its still not setting the value in callers location ?
Swathi Sarang
Well that worked, when I created that Caller's location, it was referencing to user first but when I changed it to location table it worked
