how to access MVRS variables outside mvrs for to autopopulate catalog item variables
sariksorte
Hi @sariksorte Please try this -
    var obj = JSON.parse(g_form.getValue('application_namespace_configuration'));
    alert(obj);
    for (var i = 0; i < obj.length; i++) {
        g_form.addInfoMessage(obj[i].app_nickname); //user is the variable inside mrvs
		obj[i].app_nickname = "HI";
	g_form.setValue('application_namespace_configuration', JSON.stringify(obj));
For me this script is working and setting the variables values inside the MRVS. Please let me know at which point in the script it is not functioning as expected?
12 REPLIES 12
This script is not alerting 'obj' or the info message is not coming as expected?
var obj =JSON.parse( g_form.getValue('application_namespace_configuration'));
 alert(obj);
Also, can you share the variables list in catalog item and variable set variables, so that I will try to reproduce it in my pdi.
sariksorte
landscape is the variable in catalog item
    alert(obj);
Hi Gopika,
Thank you for your quick response, it helped
PraveenK1149237
Could you please let me know is the onChnage on the mrvs or other variable if it is on other variable what will you want after accessing MRVS?
